Firmware Update time P10
Hi there - my P10 does not work properly as mentioned in another thread. Now trying to put on new Firmware. Followed the instructions and Logo on the front is blinking, every 10-15 seconds some clicking sound. Does it now for 45 minutes approximately. Is that normal? Thanks!
The flashing light shows that it is still trying to load code. This process should complete in about 1 to 2 minutes. If it is taking longer than 5 something is struggling to program. I would recommend power cycling it from the back and see if it loads the second time. If it is continuing to struggle I would give our customer support guys a call and see if they can help you get squared away.
Regards,
Matt
