FR5 Amp Pairing - Suggestions Please
Hello all!
I’m new here and this is my first post so please go easy :grimacing:
I moved out to the US 3 years ago. Back home my system comprised a Naim Unity Atom, B&W CDM1 SE stand mount speakers and a Rega RP6 with Ania MC cart and an Arcam rPhono phono amp. My main source was vinyl and streaming high resolution digital stored locally on a NAS.
When I moved I put everything in storage. I quite fancied the idea of putting together a vintage system. So after a couple of years playing with vintage gear and all that comes with it I wanted to get a new system assembled.
So taking Paul’s advice and doing a fair amount of research, hours and hours of review reading and YouTube watching I decided to join the family and buy the “best” speakers I can currently afford - a lovely pair of white FR5s with matching stands.
I already had a WiiM Ultra in use and was quite happy with that. So for starters I purchased the WiiM Vibelink. The WiiM pair sounded nice enough and had enough grunt for my JBL L55, McIntosh XR5 and Sony M77 speakers, never needing full power. As a source I am streaming Spotify and have a Beosound 9000 CD player.
With the FR5s I can easily get to max power. This is of course for short bursts and only on occasion. I have a feeling that these babies need more and would be better with ample headroom. I’m never a fan of running gear maxed out. I’d rather be sat around the 60-80 range for loud listening.
The WiiM amp is rated 100W and the other consideration for me is space. Ideally the power amp would fit in a Kallax. I’ve read some interesting articles about GaN amps that sounds like they could offer the power and size solution while also having a warmer more “class A” flavour which I do like. However I have zero experience with GaN. One that did catch my eye was the SMSL PA-X but the few reviews I had read, while quite positive the reviewers had managed to cause the amp to cut out and in one case not come back on!
Maybe in time when funds allow I can get a pair of M700 monoblocks and work out storage/size issues but until then…
Do any of you fine folks have any suggestions that would solve the power/headroom issues, fit the Kallax restrictions and not break the bank (as much under $1000 as I can be)?
Thank you in advance.
Welcome to the forum!
I must say that you’ve got a very nice system. That B&O CD player really looks great, and I like these FR5 speakers. What style of music are you listening to?
If your system lets you enjoy the music, I think I would save money and then buy the amp you really like.
Thanks! The 9000 was something I’d wanted for many years and was lucky enough to pick one up fairly cheap. It was non functional but as I suspected it was quite an easy fix for the experts.
I listen to a wide range of music. From 90s rock/electronica/downtemp/folk… all sorts really.
I can enjoy it but the FR5s seem “light” unless I get up to 40-50 on the volume. That then doesn’t give much room in adjustments. I had been used to listening at around 30 - 70 and very seldom beyond with the other systems.
The room isn’t ideal as it’s only roughly 3m by 5m and certainly needs some sort of treatment. When I am listening I pull the speakers out as much as I can but that’s not too far, around 15”.
I really like the setup you have, and oh boy that B&O is something else! Welcome to the forum. Matching the FR5’s to a good amp will bring you lots of enjoyment. I don’t have any particular recommendations but I imagine others with more experience will comment with suggestions soon enough.
This all depends on your budget, and how far you are willing to fall into the rabbit hole of high end audio. The used market (tmraudio for instance) is a great place to get better gear at reasonable pricing.
Congrats on the FR5!
Thanks you.
I’ve been following the company and Paul for a few years now and liked what I saw. When the Aspen series was release to great reviews I was eager to dive in.
As regards budget, I mentioned that until funds will allow a bigger investment I’m trying to get as much in terms of performance for as little as possible (aren’t we all!) but I also want something that looks nice, fits in the Kallax and will play well with the FR5s.
I am tempted by the SMSL PA-X as a stepping stone. If I could get one with free delivery and a free returns/trial period I would test one out. While not mega money I wouldn’t want to spend just under $1000 all in and get stuck with something that isn’t up-to-scratch. If that makes sense.
Way back when we almost bought the B&O CD player because my wife liked the look. But I bought this one instead and my wife loved the look too:
Too bad I did not keep it, and I did not even take a picture of it (before iPhone time). A few years later I moved on from all Krell to Wadia and BAT.
Too long a story on Krell SQ, but the only piece I wish I had kept is the Krell MD-10 transport.
Oh, my suggestion is not to get a Krell amp for FR5. :grin:
But a Gryphon Diablo 300 on sale would be a nice match.
This looks like it may break the budget and the Kallax :joy:
That Krell looks like a cool piece. It reminds me a little of ones the Rega and Sony did.
It might completely destroy budget, but would be an endgame integrated amp.
I have the M700’s running my FR5’s and find them to be more than adequate for the job. I usually listen at the 70 -80 db sound levels which is no problem for them. The Music Room currently has a pre-owned pair for $ 2100. They might be worth your looking into.
Thanks. I’m very tempted I must say.
I’ve been running my FR10’s with M700s and really like the synergy and headroom. I’d imagine they pair well with the FR5’s.
That’s encouraging to hear. It would be nice to keep it in-house plus I think they would suit the look too, very clean.
:+1:
  • UPDATE -
Curiosity and impatience got the better of me and I ordered the SMSL PA-X. I will post my thoughts when it arrives.
Thanks again for the feedback and advice and I’m sure this experiment will continue so please feel free to keep adding your thoughts and opinions.
:+1:
Let us know what you think! The FR5 has an impedance minimum of just under 6 ohm so we call it 6 ohm but most companies would call it 8 ohm (when you look at the overall average). The move up to 250+ watts should be more than enough. That’s a huge increase from the 50 watt at 8hom of the wiim amp.
Generally, the reviews I’ve seen on the Wiim amp is that (other than it’s large feature set) the amp is slightly on the cooler side of neutral and doesn’t have the heft of some other models.
Thanks for the reply Chris!
You have done an awesome job with these and I want to do them justice. I’m not in the position right now to spend what I would like/what they deserve so hopefully the SMSL will be a good interim solution. Who knows it could be the perfect match.
The WiiM is a good little amp but there is certainly something missing. I will keep you posted on how it goes.
On a side note, I have been super impressed with the whole PS Audio experience. Right from the start Taylor in the sales team was a great help and the fact that I’m speaking to the actual designer/engineer is very special and quite rare these days. There’s a real family here which is very important to me.
Well done all and keep up the wonderful work!
I’m really glad it’s been a good experience for you.
I do think that the FR5 responds well to different gear and you will easy hear the differences.
Paul has been great about building community and working on having a direct relationship with people in the “hifi family”. It is pretty unique, as compared to a lot of other companies.
… Just a side note Chris, it’s actually the WiiM Vibelink running at a claimed 100 Watts per channel at 8 ohms.
Not sure if that changes anything and as you say it should still be a notable increase.
Thanks.
