I heard VAC tube monos driving the $130k Gershman “Posh” loudspeakers at Axpona in either 2018 or 2019. That was a wonderful combination.
What cable are you using?
I am using Furutech pink power cable. It’s the DPS 401.
I very much like the Furutech line of cable products.
What about yourself?
Somehow I suspect that this isn’t happening. I will stick with getting my power from hydro and wind.
Nice choice. I have 2M of DPS-4.1and set of FI-50 NCF for my next cord.
I have mostly settled on Furutech. I also like WBT for speaker cables
The incoming THD on my P20 hit an all time a few days back at 10.2%. It normally travels in a range of 6 to 8%.
Even with high numbers I get a constant 0.1% THD output @ 119volts. I also have dedicated 20amp line and separate ground. The high incoming distortion is a bit unnerving but the system does not seem to sound differently on good or bad days. I guess I am ok, but may need therapy.
They are only converters, not actual power sources. Green inputs work just as well, be they hydroelectric, solar, geothermal, well you get the idea. Think of it as the ultimate Power Plant, at a price.
D@mn!t I’m not done!!!
Fine - .1% here I come… ![]()
Bet you won’t know unless you look at the meter.
Ignorance is bliss and then all of sudden you are divorced.
Wait, that’s for another forum…
Apropos divorced…I tell you a secret about the opposite:
The wedding present I got 25 years ago was…an amp…a Gryphon. Still have the wife, but not the amp.
either way gee they look sexy … Mono & Stereo © 2022: Gryphon Apex Amplifier and reckon your right Al need the stands …
What a monster.
The epitome of blissful excess.
Would love to hear the beast in a decent room with appropriate speakers some day…
Exactly.
I should get me one of those.
I know you’ve been in sunny Palm Springs, but that’s four of those…
It may look like four but its just one ordinary 450 pound dual mono amp.
How much does a refrigerator weigh?
Full-size residential refrigerators weigh between 100 and 400 pounds, with an average weight of 250 pounds. On average, French Door refrigerators weigh 317 pounds, Side-by-Side refrigerators weigh 285 pounds, Top Freezer refrigerators weight 166 pounds, Bottom Freezer refrigerators weigh 214 pounds, and Mini fridges weight 60 pounds.
Its going to cost me a fortune for an air bearing for that rig.
