High-end power cable for PSA PowerPlants?
Since the PowerPlants clean and regenerate, does the power cable from the wall to it matter as much as other components?
In my experience, yes–I actually think a bit more so.
There is no question that it matters, and in fact it affects all components’ SQ connecting to it too.
That’s why I put my best power cord to the generator.
I agree with Lonson. My P20 responded more significantly than anything else in my hifi to a good power cable.
A power plant is nothing more than an amplifier that outputs a sinusoidal signal.
The better the power plant works, the better the power supply for all connected components.
The cable in front of the power plant affects all components.
It affects the overall tone and sets the baseline. Character and timbre for everything that follows.
Spend at least $72. Oh wait, it’s you. Never mind.
you funny
I could use your advice for someone else here :laughing: :laughing:
It’s well documented on other threads thru out the forum. It is probably the most important cable in your system if you own a power conditioner. If you have a P20 a 20a service and cable is a must!
