How do I change the network settings?
I changed my Wi-Fi router and now the direct stream DAC has a different IP address. How do I change the IP address on Roon to match the IP address on the DAC?
What are the current IP addresses of each device?
Now Roon does not recognize the DAC on the network.
When you changed the router out did you leave the other gear up and running. If so turn it all off and reboot from the router forward to the DAC.
Thanks. I followed your advice, and it put me on the correct path. The solution was to unplug the DAC, forcing it to initialize again. That solved it on all renders.
