To hook up the DMP for stereo connect the HDMI cable from the left side (of three) I2S port on the DMP (marked “Front (Stereo)”) to either of the two I2S ports on the DS. To play a 5.1 multi-channel disc, you will need two more DS (or DS Jr (or Stellar DAC?)) and you hook one to the I2S port marked “Rear” and the other one to the I2S port marked “Center/Sub”.
Tho any mix of DSs and DS Jrs should work fine (or a pure Stellar setup), the delay between the DSs and the Stellar DACs would mean that you’d need something in your system to take care of the non-trivial differences in delays. I’ll keep the delays in the DS and Jr the same with a given release of the software.
