I have a pair of Infinity RS 2.5s. I am looking in to replacing the capacitors for them. Any thoughts or ideas of which caps I should use?
Do you have a schematic diagram?
Here is what I found online.
Thanks,
Kyle
ask here
What’s your budget? That matters a lot.
I was thinking around $200 but I don’t know if that will be enough. I want to replace them because they are the original caps. I want to improve the sound quality but not break the bank at the same time. Should I just replace the caps or is there anything else I could do on the Infinity RS 2.5s. Also should I replace the inductor crossover coils as well?
Thanks,
Kyle
