I have a problem with installation of Bridge II on my Perfectwave Digital. Bridge I works OK, but after inserting Bridge II, the PWD does not see the card and does not offer the input. I have the last PWD SW - 3.0.4. The network is connected, but I cannot see Bridge II as an input option.
Any idea what can be the root cause? The Bridge II card is brand new…
If you just disconnected the cable from the Bridge I then swapped to Bridge II and plugged the cable back in you are probably going to have to turn everything off back to the Router and re-boot again in order one at a time. The network is still looking for the Bridge I at an assigned IP address. You will need to let the network assign a new IP to the Bridge II so turn the PWD on last after everything else in the network path has rebooted.
