Have anyone used eLyric with iOS.8 yet with great result?
g.steve said Have anyone used eLyric with iOS.8 yet with great result?on iphone5 with ios8 elyric can't find my bridge.
but i had same issue even with ios7
i’m using PlugPlayer, and that one works fine also under ios8
I’m trying it at this very moment, although I don’t use eLyric normally. Everything works as it did before; actually I’m listening to Santana / Abraxas in 24/88,2. It took about 15 seconds to find the bridge, but since then it works just fine. Even the cover shows as it should.
Although I’m still very paranoid, after upgrade iOS8 eLyrics works as it should be… It’s necessary to reboot the DSD only… Great!!
Upgraded to iOS8, now elyric no longer works. “waiting for device” is diaplayed when app is launched. Help.
For me the app immediately ends after starting up. In short, it does not work., A pity, because it actually worked more reliably than JRiver, that crashes and hangs quite often.
