IRS V REFERENCE replica
The system was largely built by the loudspeaker manufacturer. Passive switches were completely dispensed with and the system was started up fully actively with tubes.
The system sounds fantastic, and definitely plays in the Infinity league and even better than the originals IRS V from Infinity.
2x subwoofer array / Infra 220cm (2 parts)
2x low-mid array 190cm
2x mid-high array 190cm (sand-filled cheeks)
1x MINIDSP 10x4 HD
The system consists of the following components on each side
6x 10 "Kevlar (low-mid)
9x Original Infinity EMIT 902-4578 (High)
2x original Infinity EMIT K 902-5754 (super tweeter)
3x gradient magnetostat (HIGH REAR - adjustable via potentiometer)
2x 24 "STRATHEARN ribbon (MID latest version, open to the rear, damped)
1x 24 "STRATHEARN ribbon (MID old version, open at the back, damped)
4x 15 "subwoofer / infra individual loudspeaker from the loudspeaker manufacturer
The extra sub stacks are over the top. Must be need with the smaller 10” woofers.
As if the 4 towers weren’t already over the top :wink:
Thanks for sharing this replica IRS speaker system.
:smiling_face_with_three_hearts: :heart_eyes: :grin: :partying_face: :exploding_head:
It must be quite an undertaking to built those behemoths!! Looks much better than the IRS V’s, especially those woofer towers!
The according DAC size needed would be this:
Yes, this seems to be one of two parts :wink:
Obviously the stereo vs the monobloc DAC! LOL
