Next DSD firmware update in 2020 or 2021?
Chas - I’ve been using and recording digital recording gear since it’s inception, and I remember when ADAT and DAT digital tape recorders started offering 48kHz sampling rather than just 44.1 (still only 16 bit). It was clearly audible, and opened up the top end. BUT…still, for the longest time, much early digital stuff had that sound and feel of the program material being sliced and diced. Lacking “continuousness” somehow.
Seemed crazy, but now that we hear the FAR finer subtleties of digital improvements Ted makes to the DS FW (to take one example), it has become much more experientially clear that Micro-Stuff Matters.
What I think the higher sample and bit rates bring (among other things) is to make these divisions so many, so fine and so fast that they approach analog - which translates into ease and continuousness, IMO. My two cents.
@badbeef
But the DirectStream DAC ignores the MCLK signal regardless of which clock is used on the line. The Matrix SPDIF 2 is still generating both clock signals…the switch just changes which clock frequency is sent to the pin on the connector. The Matrix SPDIF 2 is not doing more or less or different work when the switch position is changed.
How do you have insight on both clock rates being generated ? Please share those Matrix design notes on switch operation architecture.
There is a distinct difference that can be heard switching the MCLCK switch the position of DIp switch one increases the effect heard in my system. The off position of Dip switch one makes the difference more noticeable on the MCLCK than with switch one in on.
The logic says it shouldn’t matter but it is discernible.
Thank you Mark for your answer, so the more recent recording gear at 44, 96 or 192 is an improvement over gear of several decades ago even though recorded at the same rate.
I appreciate the analogy to Ted’s firmware, that helps my understanding. May I also assume that the higher sampling rates should provide more appeal to my ears (assuming everything else in the recording process remains the same)?
Yup. Though none of this guarantees anything of course. Some Redbook recordings these days are as good or better than high res versions. Plus with a DS, or other means of upsampling, you’re getting a lot of the benefit of the smoothness from there as well.
The characteristic of smoothness without detriment to other sonic characteristics is very high on my list.
I only have played 4 SACDs, and one was a sonic dud, so I believe you. And I have Redbook CDs that I play often just because they sound terrific, Graceland by Paul Simon is one.
Darren has been talking about listening to firmware candidates on his podcast, so it can’t be too far away now!
I’m ready !!!
Eagerly awaiting.
It is great fun learning what others think and exchanging reactions. A wonderful communal experience.
Happy cake day Elk!!!
Will it be like Windom that had to be installed 20 time before it sounded right, or like Snowmass the worked right first time every time?
Elk should get a whole cake, not just a slice!
Next DSD firmware update in 2021 or 2022?
I think based on what has been said here it will be this year and before the DirectStream MKII comes out.
:pray: :pray: :pray:
We are looking at launching the next Mountain Top next month, April.
Finally a light at the end of the tunnel!
Exciting times, looking forward to he upcoming release.
:smiling_face_with_three_hearts: :smiling_face_with_three_hearts: :smiling_face_with_three_hearts:
Great News. Im looking very much forward to listening and evaluating the last Mountain Top Upgrade for MK1 …
