So I switched the P10 on, noticing that everything is off, I went into options and switched all 10 to always-on. Then I noticed the voltage was like 113v and THD at 6%… My Volt meter agreed.
Turning P10 off/on then fixed the problem…
Btw: the P10 made a huge difference in the sound for the better.
