Purchased the P10 is US version, I am live in CA. My city input voltage is 120v. I have Japanese version power-amp (100v) etc.
Last night I tried to power off and power on the P10, after power on, I check the Status Screen, can see the output voltage first is 106v, then 10 sec later, change to 107v, 108v, 109v than 110v; and stop at 110v.
My question is, when in the setup, did set the output voltage to 105v, but the actual output voltage is 110v?
So, it is output the 105v or 110v?
If the P10 can’t keep the output voltage at 105v, why let the customer make such setup?
Since I new with P10, and want to make sure, my Japanese version devices ok with 105v or 110v in US.
I also have your DirectStream DAC, in the back of the DAC, the label: 110v to 120v; that means, I can plug the DAC to P10 that have 110v output voltage (even the setup is 105v for output)? Or I need to change the setup to 110v also?
If you go to the scope and then arrow through to the last page where you can set the voltage, it should go to 105 and stay there. The only reason I can think of that it won’t stay there is if you have it in the low distortion mode. The low distortion mode allows the output voltage to fluctuate slightly for best distortion.
You may also want to pay attention and make adjustments through the calibration display page to ensure that the input and output voltages track the actual voltages.
I accessed mine accidentally, by pushing the spot in the upper R corner (of the page where the “i” in the circle icon appears) TWICE in moderately-paced succession.
