I like to use upgraded power cables on my Power Plants but the spacing on the back seems a little tight between the power supply and closest high current outlet. Does anyone with a P12 know if 2 Nordost / AudioQuest / AnalysisPlus style ends would fit side by side?
All I can confirm is that you are right to worry. I used to use a PS power cord for the incoming power and there was no problem with the two Kimber PK10 Ascent cables I used for my power amps. When I switched the PS cord for the Audioquest Hurricane there was not enough room for the PK10 Ascent adjacent to the Hurricane. But I was able (just barely) to squeeze in an older PK10 with a Wattgate end. The two PK10s differ by a whisker.
