My P5 is unfortunately acting up. It’s getting power, the touch screen is working, all the receptacle s are green, everything I can tell looks fine…but none of the components are getting any power. Worked great last week, now nothing.
Fuse issue? Would that cut the power to the whole thing, or just the power output to the components?
Of course this happens on a Friday evening when the service department is closed for the weekend. SMH…
It’s weird they’d all go out at once, but also may be some circuit connecting to them. (It’s hard to tell from the schematics.) So - let’s hope there’s some firmware corruption, as odd as it sounds.
The green zone ON in the GUI doesn’t come ON because power has been detected at the outlets. It only comes ON because of switching logic in the software. This was discussed a long time ago.
Also, strange, is that since this issue started happening, if I reboot the P5, half the time it comes on in “European” mode, with the front screen showing european-styled recepticals.
A loose ribbon cable between the IO board and the output/relay board would explain both the relays not working and the European mode.
That or possibly the I/O card. So if you want to look and see if that cable is seated there’s a chance that will take care of it, otherwise it probably needs to come in.
