Perfect Wave DAC II firmware upgrade problem
Hi,
had the DAC for a while now, love it. Only now found out the firmware can get upgraded. Tried today, seemed to upgrade (blinking blue), but now stuck at “Initializing”. Tried installing the oldest version I could find here (2.2.0), did not appear to upgrade (no blinking blue), but went straight to “Initializing”. I did see a bootrescue disk for another product, but could not find for mine.
Any pointers or suggestions?
Thanks from Germany, Gerhard
Welcome! If I’m not mistaken, that can happen if the SD card is corrupt or isn’t in the correct format. Are you using a 2gb SD card?
Hi,
thanks for the quick response! It is a 2GB SD card, formatted FAT32, I just run a test, the disk appears ok, I can read the files.
Gerhard
That all sounds good. I just sent you an email with some files. Give them a shot and let me know if you have any luck.
tried with a third SD Card, which worked, many thanks for the quick help!
Gerhard
