I’m using the AES/EBU input on the PerfectWave DAC MII and the volume keeps jumping to 50%. I typically run it about 80% for my preferred listening level. Any guidance would be great. It’s incredibly annoying.
I would first try turning it off all the way (front switch and back switch) and then unplugging the power cable and all input cables, then let it sit a bit.
Edit: clarity, I hope.
In the mean time @Elk can finish his lunch…
A good power cycle should help. Do you have any other inputs hooked up? Also, what do you have powering the unit? Wall, regen, conditioner?
