Make sure you are keeping an SD card in the slot on the back of the DAC. No card, no album art.
Aha, i removed the SD card when I installed the Bridge II because I didn’t want it to reinstall the Yale firmware when I repowered the DSD. That explains why I’m not getting album art. I also don’t get the elapsed time readout. Could it be the same cause? I get the song title and data rate but that’s about it.
I don’t know about the elapsed time question but just a reminder that the old firmware can be deleted or put into a folder on the SD card (firmware updates only read files at the root level).
You just wipe the SD card (no Yale on it) and put it in as empty. Then you don’t risk any loading of new firmware - simple as that.
