Thanks for the clarification. I ended up ordering P12. I want to have the capacity to monitor my incoming AC and a little more headroom for the future. Can’t wait to share my findings.
Some people expect their stuff to work properly. Others don’t mind a few gremlins. If you’re in the latter, that’s fine, but it has nothing to do with luck.
Sounds good! Looking forward to hearing your thoughts on it
I can’t wait to get mine. I just ordered 2 of them to power 3 M700’s & 1 S300 along with a SGCD for my A/V system. I have a question regarding splitting up between 2 separate 20 amp Soloist circuits. Would it be too much of a draw to have all the amps on one SP3 which will also share a 800w subwoofer (not connected tho SP3) on one circuit and all the source components on the other? Or should I split up the amps and sources to even out draw?
Anybody know the fuse details for the p3? The manual has pictures that are hard to read, and mine is positioned in a less than easy to spot position. TIA!
On a 120V unit, 2A slo blow.
Small or 5x20mm, right? Thanks again.
Also, wondering if it’s ill-advised to run a P12 in MV with the P3 in SW? Should they be on the same waves?
