PMG DAC 512 Fuse
Using a SR Purple fuse in my DS2. Is this the same specs as the fuse for the 512? Anyone try SR fuses in the 512?
It is the same spec. I used the same M2 fuse from DS2 to PMG512.
Thanks !
I could be entirely wrong on this and I am not near the gear to confirm, but I believe the PMG 512 fuse rating is 1.25a and the earlier Mk2,was 1.0a. So close in rating that they could be interchangeable.
