Started with a Shunyata Sigma V1, Ended with a Stealth Dream 16.
I use two PA Audio AC-12 power cables with a Swiss Digital Fuse Box in between.
P12, All power cords are Inakustik 2405 Reference except amp is 4004.
I use Audioquest Hurricane.
No, I use Audioquest Thunder 20 Amp cords on each of my 2 P-20s and to get full output. I also have dedicated 20 Amp lines.
Damn, thats some clean power!
Belden’s BAV power cord for P15.
Stealth Dream 2020 on Gryphon power “conditioner”. Bottom line is treat the thing your components are plugged into like your best components.
I’ve used a Belden’s BAV power cord and a Raven Soniquil Power Cable on my P3, and found them to be essentially the same—light year’s better than the standard cable, and probably as much improvement in sound as the P3 itself contributed.
These were the ones that I remember used on the generator and a number of conditioners in the past: Anticable 3.1, AQ Thunder, AQ Dragon HC, Puritan Class+, and ZenWave PSR-11. Each one has made an improvement over stock PC.
Currently using Stealth Dream 2020 on Gryphon PowerZone instead of Zenwave PSR-11. This is not because 2020 sounds better, but because Dream2020 has more than 11 gauge so I put it in front of PSR-11 (use to power Gryphon D333 now).
I use the GigaWatt LS-2 EVO Reference Power Cord that came with my Gigawatt PowerMaster.
I use Audioquest Hurricanes for my P12s
I use the Belden BAV with my P12.
I use a much older Synergistic Research PC connected to a Swiss Digital Fuse Box with my P10.
I’m using Belden BAV 19105 10AWG cords with Wattgate Evo Rhodium connectors on my P10s.
— Chris
I needed a much longer one, so I had Signal Cable make me one of their Magic Power cords.
Using an Audioquest Thunder with P12
Love Signal Cable and the proprietor, Frank, is great to work with. Big bang for the buck products and excellent customer service.
Highly recommended.
Using the Stealth Dream 2020 on my P15.
