Power Plant Premier has high distortion and fans not working
Hi Jamesh
I’m from Indonesia
I also have problem with my PPP (Low Output Voltage & High Output THD)
The S/N is: PPP-7G116
Can i get the PPP Schematic with all support document like u have gave it to Dirk ?
Thank you so much
Np problem. I just emailed you some zipped folders with all of the info we have. Let me know in that email if you’re not able to open the zipped folders and I can send a different way.
Hi James
Thank you so much for your reply and your email
Best regards
Dear Jamesh,
I am from Taiwan. I have some issues on PPP which need the PPP schematic to deal with it. Would you please send the schematic for PPP to me, my email is…
Thanks in advance, have a nice day.
You got it. I’ll send you a zip folder with all of the info. I edited your email out of your post so you don’t get spammed.
Great!Can wait to fix my PPP.
Thx a lot!
從我的iPhone傳送
Dear James. I have some problems with PPP that need a PPP scheme to solve. Could you please send me the PPP diagram, my email address…
Hi James,
I am from Romania ,and I try to fix my PPP ,
It is a 230 V version ,can you help me please with the schematic?
Thanks :pray:
Puiu
Hi,Jamesh
I am from Hong Kong.Would you please send me the documents for Ps audio power plant PPP ? I have not the schematic to repair my PS PPP units.
Much thanks.
K.H.CHO
Just emailed!
James,
An unrelated question but perhaps you know the answer. Who is the manufacturer of the audio gear stands the PS Audio uses ?
Thanks !
Mostly Solidsteel here in the factory. Well made, look good, and decently priced. There are some custom racks around the shop as well but those were made by Paul’s son.
Thank you, James !
Sir
I am Harilal an electronic engineer from India.l need schematic diagram of Premier PP- PREM-EX Power Plant in service,can you please send a copy. My email id is rhythmhari@gmail.com
Dear jamesh,
May you be so kindly and send me all the related schematics to the Power Plant Premier (P8), please? Today, the display stops working - only two ‘-’ are visible but it’s still regulating the output. Some of the capacitors are out of spec (higher ESR than expected and degrading in capacitance). I’ll give a try to repair this unit.
Thanks in advance for your help.
Best regards, Reinhold.
No problem, I just emailed them over. Good luck!
