Will the soft start on the high current outlet be sufficient to limit the initial inrush current of a vacuum tube amplifier? I want to use it with an Audio Research D90B (90W/channel) which has a propensity to blow up chinese made 6550 output tubes on a regular basis.
Welcome to the club! Great screen name too. ![]()
I dont have knowledge that would help but someone here should be able to help.
Welcome
I have powered good sized tube amps on various PowerPlants with no problem.
Welcome to the family.
Your question is a hard one to answer reliably.
I will say that your experience with Chinese tubes is one reason the NOS tube market is so strong.
I had the same with my conrad-johnson Premier 140 with 2 x 4 KT120’s. The soft start function of my P10 completely eliminated the occasional tube or fuse blow out. Highly recommended.
ps. Also sonically the c-j pre and power amp benefit heavily from the P10.
My MV-55 and PV10AL (Conrad Johnson) get a sonic benefit from my P12. The same with BHK Preamp and M1200 monoblocks.
