Hi folks!
I Just purchased the P10 a few days ago. Plugged it in and seemed to be working. Started using it with my system (just a low powered tube amp - Woo Audio WA5, a Chord Hugo DAC, and a Macbook Pro). Noticed that my right speakers were much softer than the left. Then, after a few minutes, the right speaker failed completely.
Looked at the P10 screen and noticed that although the Setup Screen Voltage was set to 230V, on the Scope screen the Input was about 225V, but the Output was only 181V to 198V (it fluctuates)!
The scope sine waves also look strange!
The system (amp and speakers etc) are fine when plugged directly into the wall socket.
Already checked that the latest firmware is present.
Also already unplugged for several hours and replugged again. No change.
Is there something else I should be doing?
Many thanks in advance for any advice.
JJ
Screenshots attached. Apologies for the inversion - not sure why - they are right-side up on my side…
p.s. Another (small) issue - I just registered my item on the website, but even though I set the purchase date as 2015, on my profile page the item purchase date became 2014.
