PS Audio DAC Volume reset wiht USB cable
Using a usb cable into my PS audio DirectStream DAC, it automatically starts out at a volume of 50; when I set it to 92, it resets to 50 with no action on my part, repeatedly. Does anyone else have this issue? Is there a way to correct it to remain at the volume level I set?
If you go into the DAC’s settings, you are able to lock the volume at a set number. This should prevent it from doing any jumps like that.
Jamesh, thank you. Craig
Craig D. Norris
"If we don’t change direction soon, we’ll end up where we’re going."
—Irwin Corey
i was having this very same issue with my DSD DAC. The issue happened for me when the DAC was first powered up. I would set the DAC desired volume after power up, then it would go back to 50, so I got
around the issue by powering cycling the dac. Now I just leave the DAC powered on all the time.
