Up until yesterday my DSJ worked great no issues. Turned it on and wouldn’t connect. Not visible in MConnect. I have read a bunch of posts and thanks again to the user how posted to try searching 0.0.0.0.
So my issue is no link lights on the hub the eithernet is connected to or the DSJ. No DHCP address getting received, ip is 0.0.0.0.
Used a scanner to test cable, it’s good.
Hooked up another device and got link lights on that device and the hub.
Rebooted everything (hub, router, modem, DSJ) multiple times. Tried different ports in the hub. Left the DSJ unplugged all night.
Switched between static and DHCP in the DSJ menu.
And now I’m out of ideas…..
Of course its the weekend and PS Audio is closed.
The DSJ still recognizes the bridge from what I can tell, just not getting connectivity. I suppose I could inspect the pins? But it was never disconnected prior to the issue. It has been now about 10 times, lol.
If it can’t be fixed without service, would it be worth it after shipping and cost? Assuming they will still service it because of age amd parts availability.
Power off AND unplug every device in your digital chain from the router to the DAC.
Wait at least five minutes.
Plug everything back in.
Power up everything in digital chain starting with the router and working your way to the DAC one piece of kit at a time. (Make sure you wait for each component to fully power up before moving to the next component.)
Sometimes, network devices lose their “digital handshake” somewhere along the signal path and turning off the power to the kit using only their power switches won’t do the trick. It has been my experience that taking these steps precisely as, and in the order, I listed them can reestablish digital communication throughout the signal chain.
I had the same problem with the Bridge not being seen on the Network. It was after I installed windows 11.
I tried most of the things that you have already performed with no luck. But, I then installed the Yale version and then re-installed Sunlight. This fixed the issue with the Bridge not being seen to the network. But, for some reason, MQA is not working anymore which is not a big loss.
So, you could try to install an earlier version of the operating system. Good luck!
Thank you all for the suggestions. Contacted PS Audio. Apparently there is a known problem with the daughter board and heat, over time it can fail.
I was pleased with their customer service and they are going to diagnose free of charge. For me not being the original owner their service so far has been great.
Parts are not as readily available like they are for the dsd mk1.
I didn’t have that kind of luck unfortunately. My DS Jr. was DOA when I first bought it. Same issue with no Ethernet link lights on the port. Replaced the Bridge card, and all was good. Couple years later, it failed again. But no parts available. I really don’t need the Bridge anymore (I’m using an AirLens) so it functions only as a DAC. Probably won’t get much for it when I sell it.
