Qobuz on Roon skipping mid-track to the next track
In the past we had an issue with Qobuz on Roon randomly mid-track just skipping to the next track, and it seems to be back and now it’s happening more often.
We also have Tidal on Roon and haven’t noticed that happening with them.
We like Qobuz and want to keep it, but the skipping thing really bugs up.
Is there a fix we don’t know about?
Could Xfinity internet drop outs be causing this?
I’ve had that happen periodically (QOBUZ via Roon) - but it has also occurred in Roon when playing files on my server. I found it to be a home network error caused by a bad mesh wifi unit. At least, the error went away after I removed the offending unit. At least so far anyway. The cause for you may be different than mine, but I had the same type of error.
I’ve had issues with Qobuz via Roon in the past similar. I’ve found that rebooting my core and uninstalling the Roon app from my iPad and re installing it 99% of the time solves it…. The other 1% I just wait it out, it might be an isp or wifi problem and gets fixed eventually.
You could also try rebooting your router and any other equipment attached to your network.
We uninstalled the Roon apps on our iPhones and iPads and haven’t had a skip since!
Thank you,
Steve
