Remote Contol Repeaters available?
My PST and DS DAC are not in view of my listening chair, and the remote control cannot be used from that position. The equipment rack is in a niche at right angles to a loudspeaker, facing it, but it is out of view from the listening position. There must be a simple, cheap solution to this problem. I’m assuming there must be some battery operated IR repeater that sees the signal from the remote control and broadcasts it out in other directions, perhaps via an attached cord with LED or photocell on the end.
Is the remote in fact IR rather than RF?
Can anyone offer advice on how to accomplish this?
Thanks.
These work pretty well but it does require plugging in a ‘wall wart’ power supply.
https://www.amazon.com/Infrared-Repeater-Control-Devices-Extender/dp/B01N674PE9/ref=sr_1_5?dchild=1&keywords=IR+repeater&qid=1618091594&sr=8-5
Well, that was sure easy! Thanks @brett66 !
