So interesting…I was hooking up a Schiit Magni and Loki mini to my den Sprout 100 and when hooking up the analog output into the Schiit Magni input…it doesn’t work. No sound. If I use a headphone 1/4" to rca adapter from the front panel to the Magni, I get sound, controlled by the Sprout volume AND the Magni volume. Should hooking up the anolog out on the Sprout to the the input of the Magni work?
I think you are going the wrong way if I am reading this correctly. It should be streamer to DAC to amp to speakers.
