It’s Gaia2 from IsoAcoustics and not Auva, but works great for toothbrush charging…
Cleaner & brighter teeth?
Longer lasting battery should be smoother on your teeth.
Oh brother.
I like the one with bunny covering his face better, lol
You need the AUVA 100’s like Greg with the extended threads so you can tilt your speakers towards the listener. Or you can get these.
I think you need to listen to my system first.
The vibration damper helps reduce the annoying humming noise when you forget to turn off the toothbrush.
As long as you are happy that’s what matter’s the most.
This is no joke.
Raising the height of the listening chair is a legit. consideration.
Party on…
That footer is not the proper weight rating for something that light weight.
I’ve tried all the speaker height remedies to get your ear in line with tweeter. Once you have that, ADP, you can move on to making the speaker and floor connection as inert as possible. The AUVA 70 and 100’s will do that. Don’t be “stuck” thinking you’re done when a better sounding interface is available.
I’m definitely “stuck” with being happy with my system. I am suffering terribly, lol.
It should be plugged into the PZ…
Me too. More’s the pity.
Yes. You are also suffering terribly with tubes in your system.
I grew up with my Dad’s tube system and have had tube systems (only) for 35 years plus.
I now have my Voodoo Isopods here and will experiment tonight possibly. What did you hear in terms of improvement with the Isopods. Mine likely will go up for sale soon.
Only with the Jay’s they seem to sound more open and airy.
I received two sets of AUVA’s yesterday. There is a set under the PZ, Grimm MU1, and the third borrowed set I will try under a Isoacoustics ZaZen turntable platform for my curious and often confused mind.
