I have had no problems streaming Tidal via mcontrolHD app all been perfect. I went on holiday and turned all my gear off. Got back turned on and can,t stream Tidal and get message ‘delay in streaming or unsupported file format’. Have tried all the m connect apps none will work. I have done all the obvious recycling signing out of Tidal etc but nothing will play. Tidal will play through he iPad and recognises the bridge it just won’t play. Anyone had same problem or can provide me with any advice, playing Tidal in all formats is what I do most help !!!
Sound like a network issue. How about check your Router first?
If still not working, maybe you should reset the DS.
