Subwoofer cable recommendation for .1/LFE
Hi -
I’d like to hook up my AV pre-pro to my REL sub’s .1/LFE channel.
The REL accepts both XLR and RCA but unfortunately, my pre-pro is RCA only.
Can anyone recommend a good RCA sub cable?
Thanks!
I’ve always used BJC for those.
Thanks, I was thinking the same
Ditto- solid cable for LFE
Thanks!
Are you using a processor with separate amps?
If yes then you are supposed to connect an output from the amps to the high level input on the Rel.
I am and you are correct. However, for HT I also need to connect the .1/LFE channel from the HT pre-pro to the .1/LFE input on the sub.
You can’t go wrong with Blue Jean Cables.
Ordered!
Thanks everyone.
