Subwoofers - need to get your opinion
@mr-ryan-eickmeyer if you have the room, I highly recommend a pair of SVS 16 Ultra’s. :grin:
Ten inch at the max I’d say. The sub vendors SHOULD be able to properly size the sub(s) such that they work in the most linear SPL range.
I would consider one ten inch model, or like driver size. Add another later.
Your speakers are about right in the room for the same reason. Too small or big a speaker is a room can’t be tricked into working at their best.
Regards
Galen Gareis
Thanks @rower30 and @scotte1, just picked up a REL T7i. Have it setup now…wow, it’s got some balls for a little guy! More break in time now and setting up!
Cheers
Don’t be shy, get a second one. It’s so worth it.
Rythmik E15HP2. They rock! I’m running a pair with my PBN M2!5 speakers.
Only necessary if your speakers aren’t true full range. Mine are good for 20Hz at -2dB and quality of bass and integration with mid frequencies is so important to me.
Avoiding that slippery slope.
in isolation and running in a new sub the winner is the Rel S812 in the end it just was the best sub in a musical way with my Sonus Faber Guarneri Memento loudspeakers cleaner bass and just integrated really well… now saving for another …
