If this is covered somewhere else, let’s move this to the right spot on the forum.
I have one “feature request” that I’d find useful:
Ted, is there any way to provide an option to darken the display entirely unless there is input from the remote? Even at the lowest setting for the display, in a dark room, the DAC still beams out pretty strongly.
I’d like to see, “High, Medium, Low, Off” as options for display brightness. But if I adjust the volume from the remote, the display will come on to, say, Low, then black out again after ‘n’ seconds. Then again, that might be tricky to get to the settings and such if there is not display, or could cause confusion if you forget if the unit is on or off.
Just a thought…
