Yes, almost the same! And my Benalex rack originally used glass too!
Amazingly beautiful!
And the Lamborghini engine stuffed in the back end doesn’t hurt, either…
Well done! (RE: the “rack”)
Looks great! Love the organization and the all black components!
Black Widow?
Yep!
I took the opportunity to do the armboard because the Ortofon MC20 cart is being retipped.
Was actually result of a mishap. Futzing with a loose hinge mechanism for the dust cover, my arm slipped and jammed the tonearm across the platter and bent the stylus. Very sad. But it was the original stylus, and I was contemplating a re-tip anyway.
The saddest thing was that it was due by post today, and I happened to be out for a bit this afternoon, and supposedly it was a signature-required package. So, I am out of luck until monday! Grrrrr.
That is a beautiful integration into the living space, so nice to have sufficient real estate.
hi tlp
great looking system!
question for ya; is that a P10 power plant; and do you have both BHK300’s plugged in to + the front end gear? if so, at what % capacity is the P10 running?
just curious, as I have a P10 as well…and have been wondering if it can handle the two 300’s
thanks! T
Only the PS A devices, the BHK 300’s, DS and BHK Preamp are plugged into the P10. Currently, it’s only at 39%. Much less than when I had JC 1’s connected to it.
Edit: Made some tweaks to the P10. Now up to 46%. Still plenty of headroom.
We had Chris Craft 2x325hp and never worked properly despite the “engaging sound”. Can’t imagine the growling with those lambo one-off.
My dad always had a boat when I was growing up. We both had a soft spot in our nautical hearts for the wood Thompson’s and Chris-Crafts. Never wanted to bother with the spring ritual of bailing the things out for the first 24 hours of the season till the wood swelled up and sealed, though, and “glassing” the bottoms was sooo de-classe.
Those Rivas go for something crazy like $400k, I think, so for that I’d expect they’d be well sorted.
thx tlp!
Nice set up!
Does the DS & BHK Pre get enough ventilation? Looks pretty snug…
Thanks! It looks a bit tighter than it really is. No issues with excessive heat from any of components. The rack is pretty much open on all sides. There are no panels to trap heat. They are all cool/warm to the touch.
I had a Black Widow many years ago. It was a nice tonearm.
I was thinking about it, but I want something a little more serious.
