System Photos!
How about this floor, Ronald ?
people tell me Bruce Wayne was a Republican
Fake news. He was a independent. :wink:
Current backend.
Still Atma-Sphere M-60 output-transfomerless, all-triode, push-pull poweramps and Serenity Super-7 speakers… Centerstack now a Martin Logan Electromotion ELS C centerchannel speaker and Emotiva XPA-3 Eleven/1.5s 11-channel poweramp driving M-L center and all 10 ELAC B6 surround and ceiling speakers.
Frontend from the bottom… Balanced Power Technologies balance-power 3.5-Ultra 2400-Watt p-con, cablebox sitting atop the p-con, Marantz '8805 preamp/processor, and oppo '203 DP. DP drives preamp with HDMI cable; using preamp’s DAC.
All premium IC, speaker, and power cables in important (ie NOT in surround channels) roles.
In a couple weeks a black P20 will be on the bottom shelf.
I envy you for that carpet! Is it a Jan Kath?
Very nice. I’m a HUGE fan of Atma-Sphere :+1:
That floor looks rather nice indeed. I wish I was the guy would got the chance to lay it down and nail it. LOL
Is this a second system or did you replace a lot of the components? I recall you having Quad speakers and BHK 300’s driving them. Nice looking system even though there’s no PS Audio (yet).
T.Y… It’s my only system… I’ve owned the Super-7s since 2014 and reinstalled them over the winter of 2018-9… IMO, between the Quads and the Super-7s, sonic qualities in the treble and MR are approximately equal, while the dipole, servo-controlled dual-12"-woofers in the Super-7s produce bass that is substantially superior…more extended, powerful, and resolved…than that of the Quads…The 40-60 Watts of the M-60s are PLENTY enough for these 96dB-sensitive '7s.
Sold the BHK300s last fall… Was driving the Quads starting late last year with Atma-Sphere 140-Watt MA-1s; the MA-1s are now surplus.
Over the decadeds, I’ve found that I love the sounds of tubes rather than transistors, triodes over pentodes, and no-output transformers over output transformers… The Atma-Sphere OTLs are perfect for me.
:slightly_smiling_face: :grin: :smiley: :slightly_smiling_face: :grin: :smiley:
You should see the timber floor in the Zorzi home I visited the other day. American black walnut. 19mm thick, not laminate. Imported and machined on-site.
Check out the virtual display of THE RESIDENCE. It looks even better in real life. Not a hollow sounding board in the whole home, and not a nail hole to be seen. I’m guessing it has to be $300+ per square meter. Unlike my home which has a few hollow sounding boards that have come unstuck, even though the concrete was primed with epoxy.
I spy a VPI Magic Brick!
Nice Rack! Seriously.
I have a half-dozen! All are from the 1980s days of Two Jeffreys Audio; I had three and the other Jeffrey gave me his three. His are better looking than mine. :smirk:
I’ve added Herbies Grungebuster dots to all.
TYVM. It started as an inexpensive Sanus, but it’s LOTS more than that now. For instance, all sixteen tubes(1) are filled with lead shot–a mix of #8 and 8-1/2–and all shelves but the top are 3cm (1.2") granite, all but one with two layers of Dynamat the Thicker, etc.
Just this afternoon I had the bottom (p-con) shelf cut shallower so it would sit lower in the framing on the stand’s bottom to accommodate the very-tall P20 that will soon be on its way to me.
I now have about 12" between the bottom and 2nd-bottom shelf.
(1) Eight main vertical and horizontal tubes plus four front-back shelf supports per side.
And what is this, and why?
57
That’s one hell of a coincidence. My rack is a Sanus too. I guess it’s time to start modding that. Will it ever end? I hope not!
If ‘this’ means the black-and-blue pad, it’s an industrial vibration-reducing pad for, for instance, airconditioner compressors, etc. They’re available in 2", 3", and 4" squares… Here’s the 2"er…
https://www.supplyhouse.com/DiversiTech-MP-2E-EVA-Anti-Vibration-Pad-2-x-2-x-7-8
They’re HIGHLY affordable, too.
I used to spike equipment stands, amppads, and speakersystems to my concrete floor, but after realizing that even concrete floors vibrate a significant amount(1), I now isolate these things from the floor.
So I decouple the platforms from the floor and then decouple the equipment from the platforms, currently with Herbies’ Tenderfoots of various heights and densities… I also have 16 IsoAcoustics OREA equipment footers to use under my four pieces of equipment, but I haven’t gotten around to installing them.
(1) In a exchange of e-mails with Steve Herbelin (sp?) of Herbies Audio Labs several years ago, he wrote in so many words that I only think concrete floors don’t vibrate. That caused me to think more seriously about all this.
Of course it’ll never end. :grin:
Mine will when I die… But seriously…I hope this is the last equipment stand, and the last speaker systems, and the last poweramps, and the incoming P20 the last p-con I ever own.
How is the stability of that arrangement, on carpet, when you aren’t spiked to the concrete?
Excellent; the stand must weigh WAY more than 200 pounds.
