I haven’t used my Directstream DAC for a while. Now that I try JRiver doesn’t list the DAC as an option to pick. Nothing has changed in my system, house or computer. I’ve ran a different Ethernet cable directly to the modem, no luck. The light is blinking orange on the bridge, I can’t remember if that should be green.
On my Xfinity Gateway a green light indicates a 1GB connection while orange is the slower (between 200 to 300 Mps for my service) connection. One thing I’ve noticed is that sometimes having the DAC turned on beforehand will “prompt” JRiver to see it when it’s invoked.
Reset the bridge. It should show “green”. See if that helps. If it does not. Exit JRMC and close the software. Then, power down everything in the wireless and ethernet path from the DAC all the way up stream to your router/modem. Count to 20; and then power everything up one at a time starting with the router/modem and concluding with the DAC. Start JRMC again. I cannot explain why this works, but it usually restores the “handshakes” between the various parts in the “network”.
FWIW - Not sure if this applies to your situation. I don’t have a DAC/Bridge combo. I just have the SGCD. I had installed the PSA driver months earlier when setting up my NPC. I tried a bunch of ways to get my Windows 10 computer to see the SGCD - including instructions sent by PSA. The instructions said both the computer and the DAC should be on when trying to make the link.
What finally worked was to have the computer powered on, JRiver open and the PC connected to the SGCD. Then I turned the SGCD off using its rear power button (Not the front blue button) then turning it back on. As soon as the SGCD turned back on JRiver saw it.
