Thanks for your help, Paul.
I have the “Owners Reference PerfectWave Power Plant 5 Instructions for Use”, 15-059-01-1, Rev B.
Under Getting Started Guide, it refers to the “Information Screen”, on page 10. Yes, and on page 10, the main heading is “Information Screen”.
From the Instructions document, page 10:
"To enter the SYSTEM SETUP SCREEN one must first power down the PerfectWave 5 using the back-panel power switch. One must then reapply AC power to the PerfectWave P5 by flipping the back-panel power switch to the “On” position. The unit will initialize for 15 to 20 seconds. After 5 seconds of initializatiion, the P5’s touch screen will activate. After it’s activation, but before the P5 full initializes and enters the HOME SCREEN, the unit’s front-panel touch-screen can be touched anywhere on the face. This will bring the user to the SYSTEM SETUP SCREEN where the following parameters are displayed:
- Unit ID
- Bootloader3. Firmware
- Power Meter
- Oscillator
- Web
- Dimmer
End quote from instructions.
So I’m trying to access the screen that shows the 7 items above, what is being referred to as the System Setup Screen. I’m following the above instructions, regardless of what the screen’s name is, with results that I’ve shared in my original post. I just start tapping the screen after a few seconds of powering the P5 back on (from the hard switch in the back), since mine seems to initialize sooner than 15-20 seconds, but I’m still returned to the Home Screen. I’ve only seen the Info Screen once, and it flipped to the Home Screen after a few seconds, on it’s own. Thanks.
Just tried again. At 5 seconds after initialization, I tapped the screen, and continued to tap it every 1 second, until, after a total of about 10-15 seconds at most, it flipped to the Home Screen.
