I just noticed this on one of my P10s. They are on the right side of the display. I normally have the display turned off, but do check my status often. They must be quite new.
Has anyone else experienced this issue? Is is a defect in the display?
Bob
I have not seen this.
My guess is it is a display problem.
My guess is it is a display problem. :(
Yes, probably so. However, fortunately my P10 continues to function perfectly.
I have a device (not PSA) with a single line of stuck pixels on the touch-sensitive display screen. It has been this way for over a year. I will not fix it as it is $100 to do so and does not bother me. The unit works perfectly.
I bet yours will also.
I have seen this issue with other devices, and the fix is often just re-seating the connector that attaches the LCD panel to the logic/display/whatever board. And if I go to the effort of re-seating a connector I always give the contacts a light brush of Stabilant 22, you’ll never have a problem with it again.
Neat. I’ll give this a try when I get a chance.
Stabilant 22 is made in Canada, available from Aviall. A 15ml bottle will last you forever. Use it on every AV connector and power connector you have.
I bet yours will also. :)
Yes, works perfectly and not a concern.
