Anyone using Audioquest Carbon/Coffee/Diamond?
Cable Shootout: WW PS 7 versus Curious “Evolved” USB
Carbon USB A to USB 3 Micro B. Good cable. Connection from Bryston BDP-2 to SSD.
Cinnamon USB B TO USB C. Good cable. iMac desktop to PS Audio Stellar Gain Cell DAC.
I have a short Curious USB cable for my microRendu. It does a good job. Well made.
I’ve had all 3 at one time or another. I’m selling my carbon USB just replaced it with Diamond. The Carbon is good I’m still waiting a little longer to comment on Diamond it’s only been in my system for a couple weeks. I can tell the sound has more detail and accuracy with Diamond so far.
@paul172
Yeah, i got the diamond and its amazing - worth it imo.
AQ diamond rj/e (EtherRegen > Melco), AQ diamond usb (Melco > Matrix) and AQ diamond hdmi (Matrix > DS).
Never regretted the investment, amazing quality and synergy using pure silver (Siltech/Crystalcable) interconnects and speaker cable further down the chain.
Anything less than diamond is false economy
Carbon USB between my Bryston BDA3 and BDP3. I nearly ripped it back out of my system at first listen. I found it to be cold and harsh compared to the cheap Kimber USB it replaced. By harsh I mean hyper-detailed and in my face, which isn’t my cup of tea.
Glad I didn’t. After some supreme patience on my part it relaxed and I enjoy it. Would hesitate before forking out upwards of 800 bucks for diamond, though. There are a lot of options (I’m looking at Cardas high speed USB).
Yes, all AQ cables require fairly good time to burn-in. My latest addition was Coffee USB and it took a few weeks.
Yes Carbon is great.
I had the same experience as you and wanted to replace it.
I just ordered the Diamond USB B to C. It seems like this is Paul’s choice (I saw it here somewhere), for the DSD DAC.
Now, what happened to the 72V Diaelectric module? I am reading reviews from ~5 years ago, and it seems the Diamond had it, but now it does not. Anyone know why?
That’s an interesting question…? :thinking:
It actually looks like the Diamond USB “A” to USB “B” still has the DBS feature, but the “B” to “C” doesn’t for some reason…
I asked AudioQuest and they confirmed that all the Diamond cables have the unit. It’s just the website that’s wrong in the case of the B to C.
What level of gear is required to precisely hear differences between these expensive USB cables?
10k$ speakers?
You will hear a difference with them on all systems. The better the equipment the more significant the difference will most likely be. It becomes a cost consideration. You probably won’t put a $2k USB cable on a $250 Dac but I’m sure the DAC will sound better with it not $2k better but it makes a difference.
Would you say an Audioquest Cinnamon USB → Schiit Eitr galvanic isolator / coax out → Audioquest Cinnamon Coax → Electrocompaniet PD-1 is just enough? (The 'companiet is really a high performance DAC)
How does the Cinnamon series compare to the top cables?
I bought a Cinnamon coaxial cable about a month ago. After about 150 hours of play it sounded good, but not nearly transparent and detailed to justify its price tag, so I returned it. I have yet to replace it but am considering a Nordost Blue Heaven coaxial at this point. I wish there were more cable comparisons/shootouts online.
I have a Carbon USB from N100H to Matrix and a Carbon AES/EBU from Matrix to DAC. Sounds very good especially compared to the Kimber and a few other USB cables I have. Not planning to upgrade at the moment as my cable philosophy tends to be more “do no harm” then “this will be a big improvement”. I like AQ, however speaker cables and XLRs are Nordost…
Happy Listening…
Thanks, which Nordost cables do you have?
I use the Heimdahl 2 for both XLR and speaker
