Purchased DS/Bridge II - 02 August.
After short period of settling in and familiarising with the DS I became aware that Bridge II wasn’t appearing in the JRiver sidebar under ‘Playing Now’ - following waking the DS from “standby”, unless I performed a DS reboot; after which, Bridge II appeared in JRiver - and music could be streamed OK.
I certainly wasn’t happy having to do a reboot each time I switched the DS on from standby, in order to link Bridge II to JRiver.
I checked out the DS display - and the various settings, etc. and did a few presses here and there. I was encouraged when every now and then, Bridge II appeared on JRiver following my random ‘keystrokes’ - without the DS reboot.
My “refined” procedure now is:
Touch the Tool icon (top left corner of display) - > Setup - > Reset Bridge.
After a moment or two - “Voila!” - Bridge II on JRiver.
Is this normal or a small glitch, which maybe fixed in a forthcoming Bridge II update; allowing Bridge II to link to JRiver from a DS switch-on from standby?
Otherwise, the DS is running in accordingly, currently playing or on standby 24/7. And my ears/mind are also adjusting to the DS phenomenon - as being different from my previous setup.
kendrew
