I use ROON and Spotify they can not show
Sorry, he said I’ve reached the maximum number of sends, so I can’t reply immediately.
HI Guys,
I’ve just successfully updated my DSJnr to Sunlight & wondered whether iI need to update my bridgeII?
Looking at the set up screen it didn’t say update available but the Ethernet input into the DSJnr is via my Innous streamer, not direct from my switch so maybe this is causing the DAC to not see the update?
I can’t remember the last time I updated the BridgeII so I’m thinking it’s most likely due, what the latest version?
Cheers
Matt
Matt
If you are using the Innuos as your streamer then I think you need to connect it to the Jr. via USB otherwise you are running one streamer into another. If the Jr. operates like the Sr. then the ethernet input is only for the Bridge module and is not a regular input for an outside source.
Are you able provide the setup screen that shows the software version?
I am suspecting something went wrong when updating bridge online
Once you get to this page you need to press the button for 2 seconds then release, and it would start the update
I can’t help it. He just disappeared. I can’t see these settings
By the way This is how I updated it in the beginning Then he disappeared.
I suggest you update the firmware to Sunlight, followed by an update to Bridge. For Sunlight, please unplug any I2S connections and ethernet. For Bridge please connect ethernet and make sure you have a good internet connection.
Let me ask Bridge installation file It refers to Does it mean psaudio_0ug_mqrstv_v3.6.86_20190827.img?
Downloaded from here?updates.psaudio.com - /bridgeII/
First you need to download the firmware from this link:
https://www.psaudio.com/download/sunlight-for-dsj
Then unpack the files and move them to a clean memory stick formatted xfat or fat32
Update the DS Junior firmware.
Once you have completed that, you need to follow the process you have started above by updating bridge. You need to connect your LAN. Using the black button navigate to this screen:
then press the black button for two seconds in order for the DS will update to the latest version of Bridge II. Once completed, it will show the firmware version screen.
I can’t even get to the setting interface
So I simply can not update him
Did you install Sunlight firmware?
Progress!
Glad you got Sunlight installed. There are two reasons why the Bridge would say none. Either there isn’t a good network connection, or the Bridge failed.
If you do currently have the network cable connected, are the network indicator lights in the back flashing?
Yes, that is good progress
If you connect the same LAN cable to a computer does it blink?
Yes, he blinks, my internet line is fine
Ok, before you try updating Bridge two days ago, was it working?
