This is awesome! You guys are great. How hard is it to get this Roomie to add it to their library? Do you need me to help at all? I assume they'd be ok with this since it would sell some apps for them.
Let me know if I can help. I want one.
Sure, I can check this with Roomie and ask them what is needed.
Roomie clearly stick out from the competition, IMO.
There are two approaches;
1) Do it entirely by ourselves (SDK)
2) Organize the required prerequisites and let the Roomie guys take care of the rest
In the mean time, here is the procedure (from faq):
<'How can I get my favorite device added to your direct IP list of supported devices?'
Many factors go into determining which devices we support natively. Depending on the device, most are fairly easy to add and we add new devices very regularly. First, it is important to note that essentially all home theater equipment is supported by the Roomie Service available via In App Purchase when used with a compatible adapter such as the iTach Flex available in our store. Yet, the industry is very slowly (probably to be measured in decades) moving away from infrared so we offer the option to buy Roomie at a lower price without such support (ensuring we have the highest quality infrared library is very involved and we want to make sure that doesn’t get passed along unless you need it).
The advantages of direct IP support for some or all of your devices include:
More reliable command handling than is sometimes possible especially compared to line of sight infrared which is a classically hopeless scenario. The infrared adapters sold in our store for use with Roomie do not require line of sight to your devices.
Two-way communication in many cases allowing feedback on screen from Receivers, Blu-ray players, Roku, and other devices like TiVo DVRs.
Direct IP support often reveals commands that simply were not made available via infrared by the manuacturer. The list of such special commands is very long.
Back to the original question, the primary decision for us is based on the expected user experience. Some devices such as Samsung Smart TVs can’t be turned on via IP control but can be controlled well over IP once the TV is on. We’ve introduced direct IP support for Internet-enabled Samsung TVs in Roomie because of strong user demand despite that fact. If a device appears on our IP compatibility list, you can assume that exact device or one from the same family is physically tested on a regular basis with Roomie.
The existence of an Ethernet port on a piece of home theater equipment does not mean it can be controlled via direct IP. The manufacturer must explicitly enable such support. Some manufacturers have been exceptional at doing so – Yamaha and Pioneer are current stand outs (yet, the same rule applies as Pioneer just a few years ago included Ethernet ports without IP control such as the SC-25.) TiVo was an early leader, but it has been many years since they’ve made any public updates to their protocol. Some companies are just beginning to get the message now and their implementations are at best beta quality. Sony falls into that category by wrapping their very old binary Serial protocol into HTTP.
The secondary major issue is simply whether we have access to the device or have strong contact with a beta tester who can verify functionality regularly on supported hardware. If we haven’t verified device compatibility, we can’t release it. It also usually requires brief testing against the device itself in order to add Auto Discovery, and we try to make sure every direct IP device we support has Auto Discovery.
Meanwhile, it is also possible to add support for virtually any IP or Serial device to Roomie without going through Roomie Support, but that requires of course a much higher level of technical skill. See this FAQ item for more information.
'Is it possible to add support for a specific infrared, direct IP, or Serial device?'
Yes for Serial and direct IP, and assuming you have upgraded Roomie via In App Purchase with the Roomie Service then yes for infrared as well; however, you should be aware that it can be a somewhat technical process. In some cases especially for newer devices that we intend to add to Roomie’s main library, contacting Support may be helpful as we may already be working on a particular device or we may perform some of the work for you. We often add commands on the fly without requiring a new version to be released as our device library automatically updates so it’s possible for us to add necessary commands without long delays if we can verify them.
If you have infrared codes for your device in either ‘Pronto’ flat format (each code usually begins with ’0000′), or in Global Caché format (each code begins with a frequency number usually close to “38000″), you may provide them to Roomie via the “RoomieCodes.plist” file. Including such a file in your iTunes File Sharing directory for Roomie, or in the Roomie folder of your Dropbox account before using the Restore Configuration command in Roomie will cause Roomie to import all enclosed commands. It is even possible to override the commands in Roomie’s internal database with your own commands by matching the brand, model, and make of the device you want to update.
The Roomie DDK shows how to construct custom command additions. The format is identical to Apple’s plist format derivative of XML thus allowing you to use many widely available tools to edit such files.
It is also possible to add support for direct IP or Serial devices. This uses the exact same process as the infrared codes above and examples for this are also provided in the DDK. If you are adding devices that Roomie doesn’t know how to Auto Discover, you will also need to add the device via Manual IP in Roomie’s device editor.
<fieldset class="gc-fieldset">
<legend> Attached files </legend> <a href="/wp-content/uploads/attachments/64583=2377-67fce160f57a6172b8a8d6cb3828eb.pdf" target="_blank" class="gc-files">/FileUpload/9e/67fce160f57a6172b8a8d6cb3828eb.pdf</a> <span class="gc-filesize">(106 KB)</span>Â </fieldset>
