Forum just went wonky
0730 and all is normal
The top portion of the menu is still missing when I’m in a specific thread. Normally I’d select the Home menu choice and that’d bring me to all of the threads. That’s missing but if I use the back arrow that workaround accomplishes the same thing.
You’re welcome. Should be all good but please let me know if not. Is the menu showing properly so you can navigate around the site?
Please check now to see. Should be back to normal.
What URL are you on? Look at your browser window and let me know where you are going
Forum just went wonky - Everything Else - PS Audio
The back arrow works for me but the Home menu choice isn’t there. Everything (background color, search icon, etc.) else looks okay.
CORRECTION: The PSA icon is there and I can use that. It’s okay as is. Thanks for the help.
I used to work for a software company as a business analyst/product specialist and would deal with our clients all the time. Think I just fell victim to what I used to refer to as a ā€œstupid user problem.ā€
For me, Windows 11 and chrome, the standard header (Shop, Support, etc) is missing. Maybe this is intentional?
Also the PSA logo at top left used to go to the main PSA site, now it’s just a loop to the forum. Again maybe intentional. I don’t see anywhere in the thread what the goal is.
On Windows11 and Edge I have the same thing as you.
The menu on the right for the forum is fine. The menu on the left to the main PS site is still gone.
Working on it. Go to https://psaudio.com/community-forum
This will be the new address once the dns records change
Paul, maybe it’ll change, but I get a ā€˜404 Page Not Found’ when I click on that link.
oops
The forum looks a lot better than yesterday, and the black background is back. Wait, how do I get back to the main page that shows all recent topics? I need to play a bit more…
Looks OK this AM, but wasn’t there a ā€œHomeā€ button in the menu? (I’m just starting in on my first coffee of the day. . . . so . . .. ā€œ
The two PS Audio logos in the top left portion of the screen. The upper one brings you to the main/home page and the lower one refreshes the forum screen.
Cool. Thanks Joe.
In the drop down under ā€œShopā€ only ā€œAll Productsā€ could be selected for quite a while now. That is now fixed.
Some strange behavior using Safari v26.1 for MacOS Sequoia and Chrome v142.0.7444.162 (Official Build) (arm64) for MacOS.
All good on Apple Monterey 12.7.6 iOS and my iPhone iOS 18.6.2 at the moment.
