Interesting…I’ll have to take a closer listen.
I have never used USB in my system prior to acquiring the ‘Red so I did not give it much time. I just wanted to confirm it worked.
Please let us know what you find. I used the Bridge for a long time and was quite happy with it. I read the comments here about the internal card being noisy, but I never had a good way to evaluate this for myself. So I’m curious to know what you will hear when the
Bridge comes out.
Do you have both I2S and USB cables connected between Red and DS? If you do, try removing the one not in use to see if the SQ improve. On DS I remembered it made a difference without the unused link between the two devices (not a Red).
Nope.
I could not get the ‘Red to allow both outputs to be available and have defaulted to I2S, exclusively.
Got my Red yesterday.
Took no more than 10 minutes.
Compared to the Mano:
With virtually no burn-in of the Red, I would say SQ is very close with the Red slightly in front. Especially with douible and quad rate DSD which the Mano can’t do.
Given the Red can handle DSD rates > DSD64 and its DDC capability, it’s a keeper ![]()
My Mano ran RoonBridge via RoPieee. I really like that OS so I installed it on the Red.
Red works perfectly with RoPieee so I think that’s what I will use going forward.
Anyone here recall what the resolution limits of Bridge II are…?
TIA
24/192 I suspect based on it’s age
If you’ve got a USB cable laying around of any kind try it between the Red and Mk II and see if the thump goes away on the transition.
Hi I finally received my Red today and intend to use it with a Nucleus+, Ethernet into the Red and I2S out to the Mk 2.
If you don’t mind could you please let me know the correct DIP jumper settings for PS Audio’s I2S protocol?
Thanks!
According to the manual, it’s 32/192 and single-rate DSD.
Thank you.
Switch 1 off and Switch 2 on. Manual is on Kitsune website.
I predict you will discern no difference when you pull the insanely maligned Bridge 2 card out. I also don’t believe you will miss the red thing when you abandon it just for the fun of not having it anymore.
LOL.
Thanks Al….I think.
SEE
Thanks, that was my best guess from the manual, but I was confused by many different settings I’ve seen in this thread.
And yes I’ve read the whole thing and now for a second time!
It’s going to come down to your ears and not Al’s though. I didn’t hear any great difference either when I took it out but since I wasn’t using it anyway it didn’t hurt and was simple to do. So back in the anti-static back and box it went. Eliminated the noise possibility with no fuss.
I set the switches as follows:
Off (1)
On (2)
On (3)
Off (4)
These are settings that someone else posted in this thread a while back…
Ran both channel & phase checks for peace of mind ![]()
Thanks for the suggestion. I do have a big box of cables and may have a USB cable from an old printer.
If nothing else, it will be a good data point for Ted in his quest to get rid of noises during transitions.
Said box of cables is in storage elsewhere so I won’t be reporting back real soon.
It’s totally unsurprising that @scotte1 doesn’t hear a difference. It’s all about what it can do for other equipment you already adore and does it meet those requirements. For me, A+.
@tony22, what are you expecting from a streamer? Only curious. I’m specifically implying that, afterall, it’s not a DAC.
