How to install the Bridge II
Hello, I have a Bridge I and bought the Bridge II , how do I proceed ?
Any software donwload to upgrade ? Or just swap the bridge and plug the new one ?
Thanks
Disconnect all the inputs to the DAC and then swap the two boards. If it doesn’t have the newest Bridge II firmware installed it should find it shortly after you re-boot and prompt you to do the update both on the screen and in the mControl software. Re-boot it the first time with only the Ethernet cable attached as an input plus the output cables.
