Power Plant P3 Firmware Update
When it power cycles (uncommanded), it goes through the IniP3 during the restart like it’s trying to upload a firmware update (but there is no USB stick), then it decides to just turn back on again. It’s annoying because every reboot means another on-off cycle on my Kaleidescape servers, and my whole network crashes (because these are powered by the P3).
brodricj said When it power cycles (uncommanded), it goes through the IniP3 during the restart like it's trying to upload a firmware update (but there is no USB stick), then it decides to just turn back on again. It's annoying because every reboot means another on-off cycle on my Kaleidescape servers, and my whole network crashes (because these are powered by the P3).
It sounds like your P3 has some kind of hardware issue. It is not supposed to power cycle like that, But the IniP3 message is normal on boots.
Dennis
I achieve to update 0.00.15 firmware with the 4th usb stick…
Tried with these usb sticks:
Corsair 128Mb: Nok
Corsair 2Gb: Nok
Emtech 4Gb: Nok
Sandisk cruzer blade 32Gb: OK!
Files used:
http://updates.psaudio.com/powerplant3/11-065-01-X-FMC-15-9999.zip file
(given by Dennis Kerrisk on this topic)
Procedure:
Format USB stick (FAT32) & unpack files from archive
Power off P3 (back switch)
Insert USB stick.
Power on P3 (back switch).
Immediately, blue PS AUDIO logo is flashing for about 1 minute, no display, fans make noise and slow down several times, you can ear several clicks (relays) then rebooting as always.
Power off P3.
Remove USB stick.
Go to powerplay/control/refresh->it would be written firmware 0.00.15 instead of 0.00.12
If a french guy can help :)
‘Has anyone had any success applying the .15 Firmware update to a P3? I haven’t seen anything in the Forums that suggests anyone has come up with a solution (dating back to 2012), and like others’ experiences, PS support has been unresponsive
Sorry to revive and old thread but I am having no luck updating my firmware as well from 0.10 to 0.15. I’ve tried 2 different USB sticks with no luck. Any help would be appreciated.
Try this one, it it set to force update. http://updates.psaudio.com/dak/11-065-01-X-FMC-15-9999.zip
Dennis
Dennis Kerrisk said Try this one, it it set to force update. http://updates.psaudio.com/dak/11-065-01-X-FMC-15-9999.zip
Dennis
thank you but is this the one you posted earlier in this thread? If so I tried it and it didnt work.
If that does not work, you will probably need to send it back to PS Audio. You should call Alex on monday
Dennis
Dennis Kerrisk said Try this one, it it set to force update. http://updates.psaudio.com/dak…..5-9999.zip
Dennis
Yeah, I tried this one last February. She's a no work for me.
For whatever reason it worked! I am not sure if the latest ZIP Dennis posted is the same as the one he posted earlier but it my unit updated. I used the same USB stick and computer so I am not sure what changed. Thank you.
41_gif
