kdieter said
Thank you Bill and thank you Gordon for the answers.
For me, it is not the question of the quality of the updates.
I question why I am not in a position to another update, for example,
perform on 2.2.0 or other versions.
friendly greetings
kdieter
Well, you should have both.
Another trick is to unplug your DAC overnight with ALL cables [electrical, ethernet, usb etc] disconnected.
Start up the dac the next day with ONLY the power cable connected and then try a freshly downloaded firmware that is different from what you have installed. [check to front panel to dbl check what ver it says.
The PWD was off 10 hours, without any connection. It was started only with electricity connection.
The SD Card’s (2 GB) correctly inserted, golden contacts facing up.
Then I have formatted the SD card as DOS on a PC, copied files to it, no success.
Then I have copied the files from the actuell SD card -2.4.3 been in PWD - to the new SD cards, the CD cover is displayed in eLyric on a Ipad, but not on the PWD.
After the PWD started again with the “old” SD Card, the cover is now also displayed on the PWD.
I’m sure the PWD may not just read and write from the other two SD cards, with 2.4.4. or 2.2.0 versions.
But these SD cards can be read and written by Mac and PC, there are several manufacturers of the cards. However, there are regular SD cards.
The 2GB SD cards I have from PSA (one PWD update and the DS update) are both FAT16. I would start there (FAT32 may work as well, I really don’t recall if that was an issue in the past).
As I recall, the PWD expects the cards to be formatted FAT32.
stevem2 said
The 2GB SD cards I have from PSA (one PWD update and the DS update) are both FAT16. I would start there (FAT32 may work as well, I really don't recall if that was an issue in the past).
I'm using FAT16 here for my PWD/DS, supporting FAT32 is just more code and more bugs (for an embedded controller) so I wouldn't count on it being supported. Also 8.3 names for your files are needed (but PSA doesn't pass out anything else.)
So, for Beta testers going back and forth with new DS firmware versions, should they make sure the cards are fat16?
I have been using my older [fat32] for my testing since the beginning.
No wonder nobody agrees with me.
Hey, if it works, it works I’ve been using both 2G and 512 Meg SD cards for DS software upgrades, but my bridge didn’t seem very happy with random sized USB memory sticks…
Yep, It's nice to listen again. I think the fellows who were installing the new tweeters were a little surprised at what they heard when I started testing them. I think the old ones had been tortured a little too much, things sound great right now (well except that I'm tiring my ears by enjoying too much stuff too loud :) )
Exactly the same SD card I have bought in the www. Then I copied the update on it, put the card in to the PWD, take the cable from the bridge and started.
