I hope it is appropriate to post this question. Is anyone else unable to see their registered products on the new site? For some reason I get a blank page.
My registrations are there, in a pretty new format. They are on the bottom of the page (the top has registration info, etc.).
Mine show up, too, Actually, threeâŠ
All four of my pieces (300s being two) are there (with the Crosley turntable picture ironically above) reminding me that everything is out of warranty and that my DSD is very old and from 2014.
If you hover over support and then click on register products, you should see them in there.
I only get âYour registered productsâ at the top with rest of the page blank.
Yep, that looks broken. One of our web guys should have this fixed on Monday
All 7 of mine show up on registration page, but only a few on the Purchase History page.
Seems like Purchase History may only go back as far as Jan 1 2020,
(little did we know how drastically our lives were about to change)
Same here, Only show âYour registered productsâ . I am using safari on my iPad.
Try clearing the browser cache.
If you go into settings, safari, scroll to the bottom and click âclear history and website dataâ
Itâs likely the cache is conflicting with the new page, just needs clearing out.
Thanks. Doesnât work for me, still blank page with âYour registered productsâ on top.
Same here. I tried clearing my cache on both my iPad and MacBook Pro to no avail.
My registered products show up. My Power Play data doesnât show up on Firefox but does show up on Edge. If I clear the cache it shows up once then disappears. Theyâll get it figured out sooner or later.
The registration site should be up and running again.
Thatâs pretty blank.
Weird. Itâs odd that itâs working for some but not other. Hang tight for a fix.
Some of the registrations didnât migrate properly but this should be fixed soon. Thanks for the patience.
Really appreciate the follow up. Iâm sure the team is working on the issue. Thank you.
