Snowmass 3.06 Now Live
Somebody else ran into this the other day so for now I would go back to what worked until CS is back open for business on Monday.
Welcome back. Glad things are working for you and we’re happy to have you here.
Many thanks Paul.
It’s a pleasure.
Howdy @mycrowave, the changes we made should have had no impact on USB playback on Windows 10.
I spoke with our software team and they’d like to try out force load code for 3.0.6 since something might have gotten corrupted. Please send an email to our service team and they will get you the necessary files - service@psaudio.com
If that doesn’t work, the folks on the software team recommended a few other things to try out.
Keep us posted on how it goes! We’ll make sure you get back up and running in no time :grin:
I had almost same problem as mycrowave with 3.06,but usb went totally out. That happened with bridge2 installed when i changed versions back and forth few times a day. Then went back to Red cloud and it started working. Then 3.06 and no usb sound. Off went bridge2 and no problems anymore with usb.
For some reason every time i had bridge2 in,if i load new FW,does not matter which one, initializer never goes all the way and dac wakes up.
No bridge2 in and initializer goes all the way. Strange? Yes.
I noticed that about the initialiser but never had any problems. My guess is that if the bridge is not in then the ds has to spend extra time deciding the bridge is not present and times out at 100%. If the bridge is present then it’s seen straight away and stops at 60%. Just a guess.
After a week with 306 I switched back to 305 again.
306 just doesn’t make my sound better. The treble sounds of something that is a lie. There is a lot of treble.
305 makes me happier when I listen to music.
Thanks for the update - more love Michael
